I picked up a 96 Tahoe 4X4 with no motor, trans, wiring and no engine control module. I installed a 383 motor, 4L65E trans, MSD EFI and TCM. The RPO codes for the rear end are, GU6 3.42 ratio and G80 posi. Tire size is, 245/75R 16, the transfer case is a 243C electric with a 2.72 ratio. My problem is that its running RPM was 4,000, going 40 mph, in 4th gear. Found out I was in 4wd low and front differential was not engaged due to missing wiring. I hooked up a switch to the shift actuator and got it out of 4wd low.
And know I am at 3,000 - 3,500 rpm, 45 mph in 4th gear. I am thinking I might be in 4wd high? If so how can I get it into 2wd high? Most wiring to transfer case, 4low, 4hi, 2hi switches, and trans was removed when I bought this truck. For testing I removed driveshaft to front differential.
Thank you.
Thank you.
