96 tccm
mike70454
Ontario, Canada
Hello,
I am having difficuly locating a TCCM for my son's 96 Tahoe.
Will one out of a 96 Blazer fit? It has a similar 32 pin conn.
Thank you.
M
mike70454
Ontario, Canada
tccm
Hello,
Thank you.
Gzes
the drifting 2dr
Wichita tx
I'd say a Silverado one would be more correct since it's also a 1500 not a wee little blazer
M
mike70454
Ontario, Canada
Hello and thanks.
First of all I discovered there was no scan data on the Tech 2 for that year.
Jumpered pin 4 and 13. Sometimes it would read code 1, othertimes it would read codes 1 and 2, or just code 2. Seemed strange to me. Initilally all three button lights were flashing while I was driving around in 2wd (without me pushing any of the buttons). Now none of the lights are working except for the flash during power-up (then they all go out)
When I jumper the pins now, none of the lights come on. In other words, I can no longer extract codes. Either the tccm or I am confused. Never seen the symptoms change like that before yet I have never heard of a tccm failing. I believe the tccm is unique for that year.
Mike
SunlitComet
OBS Jedi-Do Good
unknown at this time.
code one indicates that you have a power supply issue with the #2 fuse 20 amp labelled tcase. it provides the hot at all times power and the code means it is getting interrupted some how. solve that first and the code 2 might clear out as well.
---------- Post added at 08:39 PM ---------- Previous post was at 08:38 PM ----------
oh and that orange wire splits in three and enters the tccm in three different cavities just so you know.
bobbydon99
