MarkD51
Hello all,
Have a couple of questions about these?
Can these be rebuilt with new bushings? If so, does anyone know where such can be gotten, to point me in the right direction with common parts stores?
If not rebuildable, where can one then get the links without too much hassle?
As some of you might know, these are different than the front, look like Dogbones.
I had changed all other bushings on both Sway Bars a few years back, but never did these.
Probably one reason I didn't, was seeing that the driver's side upper attachment bolt will be a ****** to get out, as the darn Gas Tank is in the way. (maybe an easy job for a sawzall instead, then put a new bolt in from the other direction?)
