87carl
- Joined
- Feb 21, 2016
- Posts
- 328
- Reaction score
- 169
Still haven't had any time to work on this project lately but my hours at work are getting cut back to 8 hours a day so I should get back to working on it soon. But plans are changing. She still is getting the 5 speed swap but I got an 87 parts truck yesterday. 87 is square body which has solid axle this truck has one soft spot in the frame but it's small and will be easy to fix. The Tahoe has atleast 5 rotted spots on the old frame so this one will be alot easier to repair. And my motor and 5 speed will bolt rite in this frame. I will have to change the input shaft on the 87s transfer case to 32 spline so it will bolt to the 5 speed. I need to use that transfer case because it's passenger side drop. It is a np208. I plan to start by stripping every thing off this frame so I can box it and fix the rust. Then I will set up the suspension I plan to use the 52 inch rear spring from the Tahoe in the front that should give about a 4 or 5 inch lift. Then I will use the 64 inch rear spring from the z71 and do a shackle flip which should also lift the rear 5 inches and add a couple leafs to each spring pack not alot only one or two I don't want it too stiff. After that is done i will bolt the motor tranny and transfer case together on the frame then after I get the Tahoe off her old frame I will cut the body mounts off that frame and bolt them back on the body and set to body on this frame measure from every angle possible so I know it's square and build whatever brackets I have too to connect the body mounts to the frame. The front of the 90s frame is same width as 80s frame so I was thinking maybe cut the front were radiator core support and bumper bolt on off the Tahoe frame and weld it into the 80s frame but might wait see if I can think of any other ways to do that when I get to it. 3 areas that will need to be figured out still are 1 fuel tank 80s tank is too far forward and can't use hoes tank because this frame is narrower. Was thinking maybe an 80s suburban 35 gallon fuel tank those sit between the rear frame rails I so all I would have to do is build a mount for it. 2nd issue is 4wd shifter linkage the np208 link is on the passenger side and has to move sideways slightly before going into high range I will wait till I have body on to figure that out. 3d issue steering the collumn and steering box should line up close and the 90s steering column will fit onto and bolt to the 80s steering box input shaft but 90s columns are longer then 80s columns so idk if that will need to be lengthened or shortened yet.
Oh and did I mention this parts truck was free and it's motor runs and transmission is good so I can sell them for a profit to help offset the final cost of this project which so far ain't much
