97 tahoe running hot
markman9118
My tahoe runs a little over 210 during the day with light to medium traffic. During the night or cooler months it runs under normal temp. I have a new 160° thermostat installed. But in this Texas summer, it's running a little hot. Not a lot of pressure in the upper and lower radiater hoses at operating temperature. Trying to figure this out quick.
drakon543
How does the clutch feel in the fan? Are the fan shrouds still on the radiator?
drakon543
The clutch in the fan is shot. There should be enough tension to immediately start slowing the fan down to a stop. If the clutch isnt in working shape the fan wont spin with enough force to move enough air to keep things cooled down.
M
markman9118
Thanks.
drakon543
You can either replace the clutch, go to a solid fan setup or switch to an electronic fan setup.
M
markman9118
Replaced fan clutch and exhaust manifold gaskets because of exhaust leak. Still running hot. Full of coolant.
Njoppy
