'97 Yukon Hard Shift
Trey Hardy
Eastern North Carolina
Could be a abs wheel speed sensor on the hub? Just a thought hopefully you diddnt run it hot.
Have you checked the fluid?
Throwing any codes?
Hoesgottaeat2
Western NY
Did both issues arise simultaneously? It is still possible you have (2) separate issues here. A failing wheel bearing could also be throwing the ABS light on. Transmission may be a completely separate issue. Scan it to diagnose further as @Trey Hardy suggested.
bullrunlover
