98 hoe outside air always blowing with ac off
djtlaz123
Hey Guys,
Any of you know what causes the outside air to blow in with the ac off. Any yes I have the inside air circulating button pushed.
JenneK
Island of Maui
Your question is a bit confusing.
Are you wondering why "if the recirc button is pushed why is it still drawing air from the outside?"
D
djtlaz123
Yes with the ac off,, I still have outside air coming through the vents. Even with the recirc air pushed. Its quite warm so I assume its the Arizona outside air. This is my second 2 dr Tahoe and it happened on the last one as well. AC blows cold when on. On warm nites when ac isn't needed to roll down the windows and still have warm air blowing on you from the vents is frustrating. Does this clarify
JenneK
Island of Maui
I think the term "AC" is creating confusion. If I replace "AC" with "fan", then your question makes more sense.
First make absolutely certain that the recirc door is moving. You know where it is? Does the air coming out sound different when you switch between recirc and fresh?
I suspect that the door is stuck in the "fresh" position but then again, this is all conjecture until we clear up some of the terms being used. :)
D
djtlaz123
Yes, sorry for the confusion. I mean with the fan off i still have fresh air blowing in. Where is this fresh air door you speak of.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Where exactly do you feel this air coming from? Believe there is a TSB out for that issue. Specifically which vents or area of cab if not from the vents?
JenneK
Island of Maui
While sitting in the front, passenger seat with your legs stretched out, the door will kinda be above your right foot.
Look in that area and you'll see a grated intake. That is where the HVAC fan pulls the air from inside the cabin. You should see/hear that door actuate when the button is pressed.
D
djtlaz123
that will be great is that is it. That means my ac will seem colder if i can get that closed. I'll check tomorrow. Thanks for all the help
D
djtlaz123
I pulled off the blower and closed the door. Had to use some gorilla tape cause it wouldn't stay shut. But feels like it blows a lot cooler. Thanks for the help guys.
Silveradofan34
