98 Yukon brake lights
djwomack25
I am looking at a 98 Yukon. The two lower brake lights don't work. The third brake light does. The rear lights come on when you turn on the headlights. The reverse lights work also. I have changed the bulbs and it didnt fix it. It is just the lower brake lights that don't work. Any ideas on what this could be?
Thanks for you help
D
djwomack25
Thanks! The rear turn signals dont work and neither do the rear hazards.
TigerEyz3
Slow and Steady
TN
Could be a few things, but I'm guessing that the problem is with the multi-function switch at the column. That's what I was told about mine - currently hazards don't work. I was able to get the brake lights/turn signals to work by wedging something against the hazard button. Still need to replace it, but don't have the time/money to pull the steering column apart and replace it with a $300 part.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
If all the fuses are intact then indeed your multi-switch is dueced. Specifically the hazard switch section. It has the final say on what your tail lights do under what circumstances. It is replaced as a whole assembly for about $170 for the delco brand.
memakos
