99 yukon.
LARRY M VANDIVIER
Can you put a 5.3 in a 99 yukon that has a 5.7
an is their any changes need to be made for the swap.
an 4x4 diff is leaking what would that be.
bigdog9191999
sw michigan
can it be done, yes. but it is not a direct bolt in affair. and would need a custom harness and probably tune to work correctly.
the diff could be axle seals, leaky cover, or pinion seal.
pewtermetallica
