mikez71
- Joined
- Mar 9, 2023
- Posts
- 1,352
- Reaction score
- 1,573
Just purchased this switch.. $20 from here https://www.ebay.com/itm/185091679858
Got a deal on the fuse/relay box, usually around $75 on ebay.. You can shuffle two fuses (for 1&2 and 3&4) to run off battery or ignition.
The bezel around the switches was made for the knee panel in a '19-'21 silverado.. and has a curve to it. not sure I like it there and thinking about putting it where the traction control buttons go.
It's nearly a perfect fit, just need to cut some grooves or grind down the ridges on the side for it to fit.
Squeezed it in for the last picture which is bowing out the sides of the panel..
