Hydrospec2001
- Joined
- Jul 17, 2018
- Posts
- 8
- Reaction score
- 0
Hey y’all,
I’m new to the site and I’m really hoping somebody can help with this. I know there’s other posts based on the a/c blowing hot in town but I have strange circumstances that don’t really fall under the other posts I’ve read.
I have a 2002 Escalade and when I run down the freeway it blows cool. Between the front and rear units it cools of but not to the point I can take it off max. In town it is outside temperature hot as if it is not on and only the blower is working. My first thoughts were a bad fan clutch. I replaced it and it was the same. I checked the pressures and it appeared a little low on Freon so I bumped it back up. The current pressures were 50/250 between high and low. It didn’t make any difference. When I looked at the compressor it was engaged. I turned the a/c off and the clutch disengaged as it should. When I turned the a/c back on the compressor engaged. I did notice that the compressor does not seem to disengage when the a/c is on but it still blows hot.
Well I went to a shop to have it looked at and they told me it was low on Freon and my compressor was leaking out. Interesting. I told him I just serviced it and my pressures were 50/250. He told me that I only had 12oz of Freon in the system. WHAT??? Then why was my compressor engaged with 12oz of Freon. I’m not sure at what pressure the cycle switch shuts off and on but I wouldn’t think the compressor wouldn’t engage with it being only 12oz on a 43oz system. Anyway the mechanic told me I needed to replace the compressor, drier and the orfice costing me near 1200.00. I’m fully capable of doing the work and servicing it myself but has anybody else had an issue like this. I don’t want to throw money at a bunch of parts that I’m not sure will solve it. I could sure use some help.
