MarkD51
About a year ago, I had my AC Compressor, and all other routine parts replaced, due to a leaky original AC Compressor on my 1997 Tahoe LT 4x4 4dr. (39K on the odometer)
Compressor was replaced with a new Delphi, (autozone) clutch gap appeared to check out fine at .020", new Drier-Accumilator, new stock Yellow Orifice tube both from GM, system was flushed, Compressor was first manually bench primed and professionally evacuated, charged, first with 2 lbs of 134a, then an additional .2 lbs added a few days later, bringing the total refrigerant amount to 2.2 lbs.
New Port Shrader Valves, and all seals replaced with new, no leaks. Proper Oil (I forget which offhand at the moment was used, and a UV fluid was used for future detection of any possible leaks. All appears fine, the professional appeared to do a quite through and careful job.
Upon first fire up of the vehicle from cold, the Compressor will auto cycle on and off regularly for a number of minutes, stay engaged for perhaps 10-12 seconds, then kick out for about 20 seconds. There is a slight variability, dependent upon outside temps, on average last summer, temps were in the mid 90's when this was all done, checked, and noted.
It will cycle like this for perhaps 10 minutes under my carport in the shade, then when pulling the truck out, and it's now out in the sun, the compressor on full Max setting then stays engaged, and maintains staying engaged without cycling at all. After that, under such heat conditions all then appears perfectly fine, the Compressor stays engaged,
Temps I'm getting at the Vents with a dig. thermometer on Max, high Fan speed, are running between 40-42 degrees. On a rare occasion I've even seen the Thermometer dip to as low as 39 degrees.
So then, may I ask, is this normal where the Compressor will initially cycle like this upon warm up for the first 10 minutes or so? Is this the system's way of first distributing the Oil throughout the system?
Although I am the original owner, I honestly cannot remember how the truck's AC behaved from when new, and if it did this?
Thanks, Mark
Thanks, Mark
