A/C Compressor problems
taylorham
OK I know this has probably been beaten to death but Im at a stand still.
1999 Tahoe.
Compressor stopped kicking on... It was working fine then went out and only came on twice in last month or so.
I have a new compressor, 2 new control head units. 90 degree weather and the charge was 100 psi.
I had a AC shop install compressor and charge it and it worked fine for a few months.
I jumpered both high and low switches. Swapped relays and checked all fuses.
Compressor still will not come on.
any one got any recommendations?
Thanks
Pat
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Try applying 12 volts directly to the compressor clutch.
---------- Post added at 04:43 PM ---------- Previous post was at 04:42 PM ----------
thru a fused wire directly from the battery of course.
SunlitComet
OBS Jedi-Do Good
so if the pressure switches are operating correctly and reporting to the pcm correctly then the relay to the clutch or the pcm controlling the relay is defective. a scanner that can read gm data can tell you what it sees from the pressure switches and the outputs and requests for a/c say.
T
taylorham
Found it
Connector for compressor had loose wires, all fixed
sfcadams
