A/C Cooling
sorcerer_q8
Kuwait , Hawally
Hello
I own a Taheo 2011,
Is there a solution for solving American car A/C lack of cooling ?
A/C is working fine during normal condition but in summer the temperature reaches about 50 degrees Celsius in shade. That's when the A/C doesn't give cool enough air and you can still feel of heat, is there a specific compressor for this kind of stuff or any other solution ?
Thank you.
Passin Thru
Dutchtown, LA
Have you tried to clean your condenser? Accumulators? Checked hot vs. cold side pressures for restrictions? Orifice valve plugged? Properly charged? Electric fans working properly?
There are a lot of things to check. Your question is very generalised.
S
sorcerer_q8
Kuwait , Hawally
Thanks for replaying
No I didnt check any think
Just I sind car to dealer in kuwait many time
They told me it's normal
Every think optimal
Passin Thru
Dutchtown, LA
Doesn't sound that way. You should bring it somewhere else for another opinion. Unless you plan to check these things yourself.
craniac
AC problems
My AC was not blowing as cold as it should. I am in Qatar--very close to you.
They replaced the tensioner, some belts, a pulley, and now it is colder, but not as cold as it should be.
I told them to replace the fan and they didn't. I told the dealer to replace the three-stage fan and they didn't
I am starting to suspect that nobody has a fan in stock. My mechanic says there is a three-stage fan, that looks like it is working but is actually not working during the first stage.
Now I'm looking for a compressor from the US.
Primetimetoons2
