A/C Not Blowing Through the Vents
Tthame1
I'm having an a/c issue with my 2011 Tahoe. On cooler mornings when the a/c is blowing at a low speed, air eventually stops coming through the vents. If I turn the fan speed higher, I can hear air being forced out under the dash, but nothing through the vents. Once this happens, it won't change between the vents, defroster, or dash either.
If I turn it off for 10 minutes or so it starts working again. It doesn't seem to be an issue at all when it's warmer in the afternoons.
Trc54
I've got an 11 SSV and from what I've gathered it's the hvac door actuator, I believe we have two of them.
pistolpetem9
