Can to get h/l reading posted here before the a/c is started, 30 seconds of running, pressure just before clutch cutoff and ten min later when it gets hot again. and the pressures with clutch on/off at that point. Plus outside air temp humidity Nd air temp from inside center dash vent at the same time. This could really help finding your issue for us since we are not where you are at.
