A/C Problems
tweak08
Mission, TX
for about 2 weeks now my Ac stopped working, but the weird thing is that my back seat Ac is working jus fine. Once I turn on my truck no air comes out and I have the air full blast but nothing until I start driving then I get some air flow, but once I stop the air stops too. Any ideas, has this happened to any one on here. I have a 2011 Yukon. Thanks
Erik G
Houstone Town
Sounds like the blower motor is out. When you are on fresh air (default) you are getting a breeze from driving.
Check your fuses first, I went through all the trouble of a blower motor on a Nissan once, only to find out it was a bad fuse that was loose and started to melt
Jason_S
This is a know problem on these SUVs and there should be a TSB floating around on it.
There are three possibilities: The motor, the controller (these use controllers rather than resistors) or the wiring at the connector. The TSB is directed at the melting wires/connector at the controller. To access all of it, you need to remove the cover under the dash on the passenger side. One of the screws will be very difficult to remove and is usually not reinstalled by techs. I think it is in the back corner nearest to the firewall and the center console. It doesn't have to be removed to access the controller and the fan.
Once you get that cover loose enough to access everything, check the wires for any that look melted. If there are any, then you have your problem. If they look fine, start your Yukon and turn the fan on to a setting. Then start moving the wires around to see if the fan responds. If it works, then you can replace the plug yourself or take it to a dealer. If it is still no good, then you are looking at either the controller or the fan. I was told to just replace both when I had this issue. I think parts were like $120 or $130 on Amazon. The controller is the cheaper of the two, so you could try that first.
T
tweak08
Mission, TX
Thanks for the help guys, gonna look into this. Would u guys kno if this would be covered by the warranty?
YukonCrazy
Raleigh, NC
2008 Yukon SLT
Same problem here. The blower was spinning fast at time and then slows down to nothing even though the blower was set on high. It finally stopped blowing all together. I replaced the resistor and still no blower. I checked the 40A use and it looks ok, but I will replace anyway. I guess the next step is the blower motor?
Jellis02
