Hey guys. I have a 2001 Yukon SLT with dual a/c. Does the a/c compressor ever shut off? Most vehicles I have driven, the compressor cycles on and off as the car reaches temperature.
Also.I charged my a/c, but I charged it with only the front a/c on. After reading a few threads on it, I saw that the a/c is supposed to be charged with both a/c's on.
So I put a gauge on my truck. With only the front a/c on the gauge is reading around 45psi. With both a/c's on the gauge goes up to around 65psi. It i turn the rear a/c off the gauge settles back down to around 45psi.
Also, with both a/c's on the rear blows colder than the front. Is this normal?
Should I turn both a/c's on and remove freon until the gauge drops to normal range? Thanks in advance.
