I wish to thank east302, and Red Tahoe LS for responding about the R134A capacity problem.
I thought it was 4 lbs, thanks for the info.
Last June 21 2016, I ordered AC DELCO 15-5612 Orifice tube, 15022214A compressor, and a 15-1784 accumulator
All installed at local shop that does A/C work, oil changes, tires etc.
I could not convince the the guy that did the recharge, that 4 lbs were required, which is why I asked the question again just to see if I was right or wrong.
This is how my A/C works now.
1st drive in the morning it takes 4 to 6 miles to begin to cool(@88 degrees ambient), once it does it gets a cold 38 F on a cheap thermometer.
I can live with that ( sorta), when I cut the engine off for a 1/2 hour or, so it takes 2 to 3 miles to get cold again.
When I turn the engine on, A/C off, fans off, all is good.
If I turn the fans on (heat) I hear only the 17 year old fans running, very acceptable at position 1 and 2, louder the rest of the settings, but normal, no other associated noises.
Turn on the A/C a short pause then a bearing type noise is very audible in the driver seat.
Turn the fans off... that separate noise is still there? turn the A/C off that separate noise goes away.
I have been told that it is the compressor, I suspected the clutch bearing, but......
Is there any fan or door under the dash (inside) that is activated when the A/C is cut on????
This is driving me crazy.
Again any assist appreciated.
Ron
