ABS fuse?
mattss90
Kingsburg, California
My ABS light has been on for a long time now. And I just want to get rid of it. So I bought an ABS code reader to find the problem, in case it's a speed sensor, etc... and it is unable to connect to the system. So my theory is Would this be from a blown fuse just needing replacement, or is the ABS module needing replacement?
Im thinking these may be the reasons just for the fact of the light being on. Anyone have this experience before or are there any recommendations to fixing this?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
if light is on then fuse works. Be absolutely sure your abs scanner can connect to the kelsey-hayes 4wal system installed in TRUCKS. if not then send it back. if it can then it is possible that the module is defective or the light circuit for it but there are test sheets for that. worse case have a shop that can read that abs test it for codes.
sfcadams
