ABS issues
dave76
NJ
Well I pulled the hubs and checked to see if the reluctor ring was corroded or the sensor was dirty. However everything seemed ok, so I cleaned the sensors and rings somewhat, put it back together and the brakes a liiiittle better, but every time the speed drops below 8 MPH you can still feel the ABS motor kick in. So I said eff this and pulled the ABS fuse, and the brakes work perfect now. Thinking of leaving it like this??
718frankb
LOCAL 282 TEAMSTERS
BROOKLYN,NY
are you running a different tire size than factory spec? if so you might have to re-calibrate your speedo
bowtiefreak
No Quarter
Near Philly
ABS sucks. Doesn't help you I know. I have the same problem sometimes. I run with the ABS fuse pulled most of the time
kjlegend
Milwaukee
Diddo, I run with my ABS fuse pulled all the time now. (Except during emissions :)~
Gotcha12
