ABS lite
greenhornet
Ontario,Canada
Can the ABS be disabled in a 2000 Tahoe LT 4WD. without the warning lite coming on.The ABS lite does not come on just the ABS activates at slow speeds (i have done many sensor cleanings and bearing replacements,)I was just curious if the ABS could be disabled and i would have brakes that i control,not a pump.
gitrduun
Take the fuse out , pull your cluster apart and unplug the light :)
Skizzot
Usa
Take off your Electronic Brake Control Module, put it in a box, and mail it to me (I need one). Then pull the cluster and disable the ABS bulb and possibly the parking brake indicator bulb since the absence of an EBCM may illuminate that one as well. Or just stick some electrical tape over the indicators to block the lights.
Ejwr
