abs speed sensor fl wearied
dhg4dragon8
Rison, AR
i just got a 96 Yukon for a steal, but the abs light is sometimes coming on
with a no signal from the sensor. but some times i can go over 100 miles abnd it never comes on. i am thing of a broke wire on the sensor. but i would like the collective advice of the form.
also wean the abs is active the brake pedal move will move to the floor
qukon 95
Replace sensor it won't tell you which one is bad do both and check for leaks. Good luck
dylansmashed
