If it does clog the likely source of debris is from the condenser as they break down from the inside. Also from inside the compressor. If a compressor needs replaced and you open an a/c system and start replacing parts, you will see debris in the orifice, which is normal after so much time and pressure works on the inside of the system. You always replace the compressor and the orifice and the accumulator. You would also always flush out the open system. IMO, the condenser should be replaced as well. Small passages in there break down and get clogged and make a big difference when it comes time for the condenser to dissipate the heat that is sent to it. If old enough I would change out the hoses as well because they get debris embedded in the inner linings of the hoses. Thankfully, the evaporator is stouter and can take some crap before it needs replaced.
