Ac compressor issue
psfr311
Lawrenceville, GA
I have a a 99 Tahoe with a fairly new ac Delco compressor. Last time I used it a few months ago it had no issues. I went turn it on yesterday and it wouldn't get cold so I figured it needed freon. Checked under the hood today to make sure it all looked good and i noticed I can't get the compressor to engage. The plug going to the compressor looks good not sure what the problem is.
Any ideas?
P
psfr311
Lawrenceville, GA
ok ill check the freon. Ive never had an issue leaking freon before. but theres a first time for everything
P
psfr311
Lawrenceville, GA
went to pick up freon yesterday for it, the guy at the auto parts store told me i need 61 oz. of freon (i have rear ac). that sounded like way to much so i didnt get any.
he told me also to remove the relay and run wires directly from the battery into the compressor to see if it will engage or not.
any thoughts on doing that?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
All it will do is tell you the clutch work and one of many other things don't. I would have only added one or two cans to see if the system would boot up. if so then a leak was the issue especially on a compressor that is not run for a few minutes a week. Not running it for several months can cause the shaft seals to dry out and leak. Among other things of course.
P
psfr311
Lawrenceville, GA
ill make it back by there and get a can. the ac system is fairly new so im hoping just a leak and not a larger problem
---------- Post added at 02:32 PM ---------- Previous post was at 02:23 PM ----------
im also reading to add freon with the a/c compressor engaged..
SunlitComet
OBS Jedi-Do Good
yeah add enough to get it started and it may go slow going in. once it starts up add it when the compressor is running. it goes in faster becuase you add it to the suction side which has the lowest pressure point when running.
P
psfr311
Lawrenceville, GA
just added a can and the compressor engaged then disengaged. only engaged for 1 second at a time at first but by the end of the can it was engaged for 5-7 seconds before disengaging. i assume it just needs more freon. back to the store
mrkkrnr
