Ac problems
Roy Hampsten
I have power at the relay just replaced that as well but I have no power at the compressor it self? I know the switches are known to go bad but would I still have power to the relay? Help
east302
Mississippi
This is for a 1998, I assume that the VCM provides ground for the relay, allowing voltage to the compressor clutch. A4 at the relay is hot with ignition on.
I'm pretty sure you can jump the cycling switch (on the accumulator) to see if the compressor kicks on. Temporarily, of course, in case it is a good part and legitimately shutting off the compressor due to refrigerant issues. The switch is maybe $5, and is on a schrader valve so it can be swapped out with minimal refrigerant loss.
devingcore
