Acuator box 2002 tahoe
Antdogbmx
My air is coming through the defroster vents and not the dash. Was told if I disconnect actuator box it will come through the dash. If this is true I could use some guidance with this as I have never done this before
best option is to just replace the actuator, unplugging it to move the door is a option but you will probably want your defroster back at some point in the seasons
not sure exactly where that actuator is but it is likely up behind the radio or you may have to pull the passenger side airbag to get access to it.
@yates ™ could you move this to the right section.
Fless
Super Moderator
Elev 5,280
Have you tried an HVAC reset procedure with the Tech 2 or the manual process?
OklahomaSideShow
