Adding a Key FOB
deltabowhunter
I only have 1 Key FOB for my 2015 Chevy Tahoe LTZ. I need to add a 2nd FOB. Is this something I can buy online and program myself?
What about the actual key inside the FOB? How would that piece work?
Big Mama
Virginia
Unless you have a Tech2 or other higher end programmer you’ll need the dealer or someone with one to program it. The key is another story and most likely the dealer. It’s going to cost more but you don’t want to buy this again. Go to the dealer.
The Tech2 does not work on the newer K2s, there system is the MDI or MDI2 and the GDS2 software. Anyhow, if the Tahoe has Keyless Access, the instructions are in the owner's manual, you can add new fobs, up to eight.
Big Mama
Virginia
I stand corrected. I’d check what you’re buying to see if there’s room for the physical key in it. I’d still guess the dealer for a key
Yeah, at the least he can get another key for the fob from the dealer and have them cut it but locksmiths should have them too.
D
deltabowhunter
It has keyless entry and push button start. Evo, the owner's manual should have the info to program a remote that will unlock and start the car?
Sent from my SAMSUNG-SM-G930A using Tapatalk
QUYHMK
