Oh, I misread this. You are wanting to add a newer model console that has the bose amp and sub in it? Technically, you could add it in, yes. But wiring it up would be a real pain in the rear. If the console is NOT from a Denali/Escalade then it has the more basic amp which if you really felt like it, you could wire it up. The amp in this console does not need a Class 2 signal to turn on. You may have to find a bose radio out of a 2001-2002 Denali or 2002 Escalade for it to work. It'd be a lot of work, but yes, it could be done.
