Aftermarket headlights for 15 tahoe
Kinneyj14
Hey I own a 2015 Tahoe and I'm looking to replace my headlights. Has anyone done this yet? I thinking of going with anzo headlights but I'm not sure what kind of quality they are. Last thing I want are cheap headlights that break or fog up.
Vanquish Auto
202 Wallace Ave N Unit 12 Lehigh Acres FL 33971
Hello, welcome to this forum. You will never want to have aftermarket headlamps, aftermarket headlamps quality are the worst. Also the comes with projectors but its just halogen H7 projectors ( means you will be just downgrading your visibility. Luck!
burbplayer
hello, welcome , i will never buy any aftermarket headlamps when you have the best option to replace your halogen bulbs to the brighter lights. I got all my led and hi lighting from vanquishauto, they are also sponsor vendor in this forum, they have the right products for your car.
I will recommend you to get their lights, the hid kits and led kits they have do not require any relay harness, its all plug and play, no error message and you will definitely improve you nighttime visibility and give your car a fresh look (in fact) this is the only hid kit i have found that is made for my car without needing relay harness and no issues at all.
Here is the link for the items you are looking for:
LOW BEAMS
https://vanquishauto.com/headlight-bulb-low-beam-h11-3018.html
HIGH BEAMS
https://vanquishauto.com/headlight-bulb-high-beam-9078.html
FOG LIGHTS
https://vanquishauto.com/super-bright-led-fog-light-bulb-front-replacement-pwy26w.html
Pohlease
I agree with the other guys. I bought after market headlights before and they were terrible!
fozzi58
North Jersey
Vanquish Auto
I've been thinking about pulling the trigger on the Anzo's I like them a lot. I would probably replace the bulbs with better units, but the look of the headlights make a difference. Plus throw in the $155 cable to keep my DRLs on during the day and I will have a badass looking headlight. Its too bad there's no way to convert to the LTZs daytime LED strip otherwise I would.
http://www.anzousa.com/chevy-tahoe-suburban-15-up-projector-u-bar-style-hl-black-clear-amber.html
They are nice. You should be good with those as long as you don't put some led kit on the projector low beams.
K
Kinneyj14
Okay so let me start by saying I should of listened to you guys, I did "pull the trigger" on the Anzo headlights and although they looked great they had one major flaw. After installing the driver side with ease, I moved on to the passenger side. The bottom bracket is improperly designed. It rested almost one inch deeper, not allowing the headlight to fully rest inside its cavity. I tried to call Anzo but they were closed so I have no idea if it was a assembly error or if it's a real design flaw. Either way I decided to return thing to autozone
BK613
