Aftermarket/ Replacement Front Sway Bar Endlinks?
unoigo
Detroit
Has anyone replaced their front endlinks on a Tahoe or Escalade? I could have sworn I have seen them, maybe for earlier models. I called Energy Suspension as they don't have a direct fit part. Said to measure stock and check their fitment guide... which I will probably end up doing. Wanted to see if anyone else has done this mod. I did find an AC Delco Performance kit that is direct fit but it has blue bushing. Don't really want that with all the red I have going on with the Eibach Sways and bushings. Thx
08grey
Go to autozone. They have all the universal kits. Measure the length you want and boom done. It's like $20. If your lowered in the front go a inch or so shorter to bring the bar level.
unoigo
unoigo
Detroit
Thanks guys. Yea I'm lowered and the front sway bar is not parallel with the control arm. So wanting to correct that. Thx!
justinesky
When i lowered my escalade i cut an 1 1/2 off the middle of the end link 9plastic spacer part) and put the 1 1/2 part on top of the sway bar and before the nut. Did this a long time ago and all is working well.
08grey
I have a set of oem ones I'll sell ya for 25 shipped.
steveo346
I just replaced mine this past weekend on my 07 z71. When I purchased my Tahoe. the bushing were literally gone, and the truck swayed like no tomorrow. Autozone had them for $16 each. They took some finessing to put in, the stock swaybar little bar in between the sway bar and lower control arm is shorter than the one from Autozone. Feels 1000x better with the new bushings.
unoigo
unoigo
Detroit
Nice....I have yet to put mine in. But need to as them OEM links are worn out too.
