Aftermarket weatherstripping / Door seals
opfor2
Riverside County, CA
I need to replace both drivers and passenger's front door seal/weatherstripping on my 2011 Tahoe. I'm going to buy them from RockAuto however, they only have aftermarket brand. FAIRCHILD G3160, AUTOTECNICA GM0818589, and PRECISION DWB111007 which would you choose?
You can also go to GMPartsDirect.com, enter your VIN, go to the body section, and look for the exploded diagram of the door. You should find what you are looking for along with the correct part number. And, the cost will be significantly cheaper than the local dealer.
AnthonyGaines
When I had to replace door seals on my car, I found it really helps to look into how they’re made.
Daverole
