they should be able to be accessed from under the truck, depending on the year they may bolt up from the front of the sensor or they may be bolted from the rear with a reverse thread I think they changed in 2010, so 07-09 should bolt from the front of the sensor and 2010-2014 should reverse thread from the rear.while doing my trans cooler i had the front fascia off and noticed to impact sensors mounted on top of the front sub bumper on the left/right side. You must remove the front fascia to access them. you need a good scan tool/tech2 that will determine the failed component?
service manual doesn't say anything about having to remove anything other than loosen the bolt
View attachment 252948 View attachment 252949
the design change creates some confusion on my Yukon I can access them from the back using a star bit and turning counter clockwise I think that is the only way unless maybe you tore the whole front end apart which is ridiculous. the service manual doesn't even show them for the yukon you have to go look for them because they are not where the diagram showsI never doubt
i never doubted you were right cause you have some great knowledge! If you crawl under you will never see them cause they are concealed by the sub bumper, But if i pull my head outa my ass and look through the front grill they are mounted on top as the diagram clearly defines!![]()
