Air Bags
gibsonm21
San Diego, CA
I'm looking into bagging my truck and I want to know if there is any obstacles that i'm gonna come across having it put on. I have an 08 LTZ w/ auto ride.
Also, Has anyone ever dealt with Airbagit.com? They seem pretty legit, but I'm new to the suspension world. Any other good places to look?
Thanks
NASTY GM
Nor Cal
If your going to just bag it your ok. If you want to lay frame or boards your looking at a lot of fab work. What are you planning?
gibsonm21
gibsonm21
San Diego, CA
My plan is to get a plug and play kit from airbagit.com and swap out the stock shocks and struts if I can just do that.
Is there a reason that I would have to do board work? I don't know.
bigblue
Beaumont TX
i have thought about buying from that same website you are planning on using. It can be done if you just want air ride suspension. If you want to lay frame you are looking into a lot of fab work to get the wheels to tuck. What size wheels do you plan on going with? You can buy 4 bags that replace your struts/coil springs on all four corners, all the valves and lines your going to need, plus compressor and tank, with a simple control board for about 1500-1700. Where you can spend lots of money is in the control board. You can build a kit like this one for less than 2000$
http://www.keldermanairride.com/lift-kits/project_vehicles/details.php?id=GMT900
Jellis02
