Air Control module not working
RedCrush
So heres, the deal, I recharged my AC and it was working properly. But every now and then the AC would stop blowing and I would wiggle the ac control mondule and it would come back on. Well now it doesnt come on at all. Nothing blows on any speed, etc.... Do I need to replace the whole entire AC control module, or is there some trick I can do to get it to work.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
FAN SWITCH.
sometime it will fail or the connector gets burned up. when you turn the fan off the a/c and some other functions get disable by a 12v signal from it so if fan switch is ever off and you can select the mode door or turn on the compressor your switch is broke.
RedCrush
RedCrush
the switch that is by the compessor correct? with the two wires going into it?
RedCrush
RedCrush
cool so i ordered it..should get here tomorrow. so where does it go??:favorites37:
SunlitComet
OBS Jedi-Do Good
pull the fan speed knob off controller and unsnap the switch module from the back. and inspect its wires and connector too. if they are damaged replace those before reassembly.
RedCrush
RedCrush
Thanks for you ongoing assistance! YOU DAMAN! I'll probably get to it today or tomorrow. No rush for the ac since a cold front came in..
RedCrush
RedCrush
I have alot of insulation... lol
---------- Post added at 01:41 PM ---------- Previous post was at 01:38 PM ----------
oh yeah and even with the cold front, our high is 70 which is pretty nice.
RedCrush
RedCrush
Thanks sunlit.... Installed the fan switch... Problem solved...
Coolwhip69el
