Air suspension
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
back is easy i posted the tbss bag swap. the bags are like 275 at daeler and truck lays on axle then you wil need the rear djm hardware kit with bumpstops which i sell for 190 along with belltech sp shocks 125 and the rear spohn panhard bar 135.
i sell all that stuff
B
Bxbound7595
What about the front ... By the way that escalade is fire I follow you on Instagram
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Spindles ate 280 and you will need to do a air strut set up
B
Bxbound7595
Could you send me the link on how to swap the air bags so I can fit them on the 2015 suburban
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
you will need the tbss airbags and then some 5/32 line to plug in to the bag. from the 5/32 air line youwill need 5/32 to 1/4 inch push to connect fitting adapter then 1/4 inch line to your compressor.
the tbss airbags spin right into the upper frame and you will need the rear parts from me (shocks/extenders/panhard bar/endlinks/trailing arm relocators/bumpstops)
black2002tahoe
