Air won't blow out vents
Mike_oat
Hello,
I have a 2009 Tahoe with climate control. It has the digital setting controls. I'm having a problem with air not wanting to blow out any of the vents. It won't blow out of the dash vents, defrost, or the floor vents but I can hear the blower motor on. It is blowing hard but it almost sounds like the air is being blocked off from blowing out of any of the vents but air still blows out my rear air vents at all times. This happens with the heat and A/C. Any help would be greatly appreciated.
Thanks
M
Mike_oat
A/C
Hello,
Thanks
M
Mike_oat
Problem
Hello,
Thanks
GM Customer Service
Michigan
Hey there Mike_oat,
Having an issue with climate control in your vehicle? I see that you are seeking information to fix this issue. I am sorry that you are experiencing this issue with your vehicle. I might not be able to provide you any technical advice but I would be happy to look into this concern. Please contact me via private message if I can be of any assistance.
Jennifer T.
GM Customer Care
YukonXLPerk
Check to see if you have anything blocking your AC inlet. It should be under the dash on the passenger side. Sometimes "floating" debree from late night Mcdonalds binges can get sucked up into it.
Your rear air is working because it is pulling air from the rear of the vehicle. It obviously is not blocked.
tanguycryms
