Alternator Bracket
Nicety
Great Mills. Maryland
Hey all, I have a 2003 Yukon and I have a problem with the alternator bracket. The part of the bracket broke off with the bolt. Does the power steering pump have to come off in order to change that whole bracket? What the heck is it made of? It looks like it was over torqued last time the alternator was changed. The crack looks old as dirt. Anyway There probably is no way around changing the whole blasted thing I guess? Thanks for all the help!! Love this forum!!!!
Big Mama
Virginia
Got a welder or know someone who does? Otherwise a wrecking yard will have one cheap.
strutaeng
Dallas, Texas
Yup, PS pump has to be removed, as bracket bolts to both PS pump and alternator.
Rent to PS pump pulley puller at the local parts store. The bracket is aluminum.
You can source another good bracket at the wrecking yard. Should have a good inventory as pretty much any LS-based family of engines is the same part: 4.8, 5.3, 6.0, 6.2 truck or SUV, doesn't matter.
