Alternator Connector doesnt fit.
CS144 Conversion
Just replaced my 105 alternator with a 140, everything bolts up but the connector doesnt fit into the back of the alternator?
Solutions?
Thanks!
Ok so apparently i need to convert the harness to a CS144 connector. Any ideas?
grnrpr68
Davenport IA
you might have to go to the local electrical shop and see if they have a harness that will fit
---------- Post added at 10:56 PM ---------- Previous post was at 10:55 PM ----------
the shop that i have here in town that built my 300amp alt had a harness that i had to wire into the truck that would fit the alt no big deal to wore but you just have to see if they can get you one for your alt
steamroller
The South
Go to the junkyard and get the connector from a TBI truck or GM vehicle, the CS144 uses the older style connector like this, or the local parts stores usually have them for $10-$15
M
Do you know how to connect this into the existing harness?
steamroller
The South
When I did mine I got one from a TBI truck, it's only 1 wire so there isnt really a wrong way to wire it in, cut the old one off and solder in the different plug..it's a brown wire IIRC
Z71JimmyK
