Aluminum LS Block
I took a pic of an oil sender on an LS motor yesterday, I didn't realize it was an aluminum block. Pretty cool. This came out of an Envoy, and it's the 5.3.20171127_134125.jpg 20171128_131346.jpg 20171128_131432.jpg 20171128_131449.jpg
Nice. Motor had an issue so it was yanked. An iron block is going into its place. Motor is fixable but they didn't want to bother. I think my buddy might eventually scrap it.
If the block is fine, they bring a few dollars.
That'a an LM4, the LM7s cousin. The L33 has a different block number and was only used in full size, extended cab pickups. The LM4 was used in the 2003 and 2004 Envoy XLs.
Forgot about the LMs- nobody ever mentions them. You would be the one to know! lol
What're the differences?
The L33 was marketed as an **, or Vortec High Output; something like that. The engine had a "bigger" camshaft which, coincidentally, is the same grind in our engines. That was the most powerful 5.3 Gen III engine. Not that the LM4 is no good, it's power rating is 5-10 hp less depending on the application.
plazola132
