Amp remote wire
02_Tahoe
Maryland
When I was wiring my new amp and came to the remote on/off wire I just cut the blue/white wire coming out of the head unit and attached the remote wire to it. When I tested it out later the door speakers didn't work, then I realized that the blue/white wire was the remote wire for the stock amp, so right now I have 3 wires spliced together. So basically my question is, if I bypass the factory amp do I need to worry about the remote wire or will it not matter anymore since the door speakers aren't powered by the amp anymore. It's hard to explain what I'm trying to ask so hopefully someone understands
YukonXL04
The Riverboat
Arlington, TX
If you bypass the stock amp, you no longer need a remote wire to turn it on as your not using it anymore. But any other amp you have will need it.
02_Tahoe
02_Tahoe
Maryland
Ok thank you. Is bypassing the amp as easy as cutting the wires that go in and out and splicing the same colors?
No you need to run new wires from your new amp to the door speakers. That's probably why your door speakers don't work.
02_Tahoe
02_Tahoe
Maryland
No they work now, the new amp is just a sub amp, the first guy answered my question I just need to know how to bypass the factory amp to have the door speakers run off the head unit
YukonXL04
The Riverboat
Arlington, TX
Yes you can do that. You don't have to run new wires to each speaker, just better that way.
Not entirely sure the wire colors are the same for in and out of the amp though. Been a while since I have done your year.
No they work now, the new amp is just a sub amp, the first guy answered my question I just need to know how to bypass the factory amp to have the door speakers run off the head unit[/QUOTE
Glad you got it working. Just run new wires from your new HU to the speakers and leave the factory amp without a turn on wire.
02_Tahoe
02_Tahoe
Maryland
Ok thanks, I'd rather splice them since it sounds the easiest, I'm not the best with electrical work, I'm surprised i got the sub and amp working on the first try
tahoe_highcountry
