Another d*mned wheel/tire question
TahoeJim
SE Ohio
I've been talking to 3 different tire shops and checking online with Tire Rack, Discount Tire, etc as to what will fit my 99 which has old 245/75-16's on it.
I have a chance to pick up some new MKW 18" wheels with equivalent to stock offset at a good price. Per the first dealer, 275/65-18's will work on a stock Tahoe, no lift.
The 275's are 32.1" diameter compared to stock 245's which are 30.5"
275's are 11.2" wide section width, the 245 stockers are 9.8"
Another dealer says no way, I should stick with a 17" rim and a 265/70-17. That tire has a 31.7" diameter and 10.7" section width, about identical to the 18" mentioned above.
Third dealer has his own ideas. All I know is the 245/75-16's look like compact spares in the wheel wells.
Anyone here mounted up some 18's on a stock OBS Tahoe, what fits, what doesn't?
Signed,
Frustrated in NC
sc00bz
South Paw
Alot of the fit depends on what the wheel's width is. If you could post that, it would probably help people give you advice.
TahoeJim
TahoeJim
SE Ohio
I did omit some important numbers...
17 x 8 with 10mm offset, 4.89" backspace
18 x 8.5 with 10mm offset, 5.14" backspace
I've searched for the stock 16" wheel specs to compare backspace, no luck as of yet.
DJTricky
Banned
Robbinsdale MN
a wile ago i had some 285/60/18's on mine the back spacing was 5 1/4" here is an ok pic of them.
they even fit with the drop kit on
i have now gone ti 255/50/18 lol they tuck better
TahoeJim
TahoeJim
SE Ohio
Strange turn of events but I'm picking these up with 265/75-17 all terrain tires in about a week.
Bad bow tie
Grizz Straight FTMFW
Michigan/NC
If it's a 17" rim, I would run a 285/70/17. It's about a 33" tire and should fit with minor torsion bar cranking, if any.
TahoeJim
TahoeJim
SE Ohio
Hot damn I can't believe the difference. Between the tires, wheels, new shocks, adjusting ride height and a very thorough alignment....it's a different truck.
09Yukia
