Another Intellibeam question...
John Stevenson
Hey guys,
Question about Intellibeam...the manual isn't really clear on this.
Is Intellibeam active when you are in low beam mode (to turn ON high beams automatically if no other cars are around).
OR, is Intellibeam active when you push the light stalk away from you to enable high beams (to turn OFF high beams temporarily if a car approaches).
Thanks!
Kpwweb
Low beam or automatic mode with the green "A" headlight lit up.
scott6760
Flick the headlight stalk forward to 'high beams' and then back off again quickly. That should activate the automatic mode. If you turn the fog lights on it disables auto mode temporarily.
aggie2013
