It will happen on the G3 and G4. There is no traditional flasher unit. When you get your g3s or g4s, there is a black box. unplug the black boxes from the back of those taillights. Order the 6 ohm resistors from vled, cut off the light side of the said black box harnesses, and splice either end of the resistor to the two wires that used to go into that black box. It does not matter which wire goes to which side of the resistor, just tap into those wires with either end of the resistor.
The brain for the blinkers will now only see 6 ohms coming back through those wires instead of 12 ohms like the black box that you just unplugged will show the brain. Therefore, the brain will not think there is a lightbulb out and make you hyper flash.
Took no more than 10 minutes to install... no hyper flash at all since then...
