Another Lift gate problem (Broke again)
SpareParts
North Idaho
I can't seem to figure out this FU*&)ing thing. Rear lift gate open message on DIC
I have replaced all the struts. 2 for glass and 2 for the gate.
I have replaced the Lift gate drive part on the lift gate motor. Lift gate motor does function.
I have replaced the Lock actuator on the door. Tried 1 new one and 2 used ones.
The switch on the outside handle is new and checks good. As did the old switch.
The window will open with the fob or button on the door.
Checked and cleaned the switch on the window latch. It tests good and functions as it should.
When I push the open button on the over head I can hear the module in the rear click but nothing happens.
When in auto mode, the tail lights flash when the fob button is pushed but nothing happens.
When in manual mode, pressing the switch on the outside I get nothing. Tail lights do not flash. Nothing happens.
The 15A fuse is good and continuity tested.
It's almost like the rear gate has no power but the glass part works as it should, so I would think the power is good.
The main wire plug for the tail gate is good with no burned connectors.
I guess the big clue here would be the tail lights not flashing when the outside switch is pressed?
I need some help with this as I'm at a total loss now on how to continue.
I can't seem to find a test procedure and this type of troubleshooting is not my strong point for sure.
Anyone offer so help?
SpareParts
SpareParts
North Idaho
The 15A fuse has no power to it when tested. If I put power to it, nothing happens either.
mikez71
Is it not opening because it thinks it's already open?
Maybe something to do with the liftgate sensors?
I think @Doubeleive has pictures of them.
Here's a thread that shows the liftgate open wiring in BCM...
You should be getting a trouble code or two in the BCM. Take that code or two and run them through the troubleshooting guide in the shop manual.
Charm.ii for the freebie or AllDataDIY for a subscription.
SpareParts
SpareParts
North Idaho
The sensors on each side are for door obstructions. I had to research them after he posted that info about them. They could be unplugged and the door would still function.
The BCM the other post shows is for an older Tahoe, pre 2007 and nothing like my BCM.
Messed with it for a few hours this morning but not actually changing anything and just could not make it work no matter what combination I pushed switches.
Tried my scanner but it can only open the back glass. It can not work the rear lift gate and has no option for it
There are no codes in the BCM.
After 2 days of messing with it and getting frustrated it magically fixed itself. I have no idea why it started working or why it was not working.
It now opens with the remote, the inside switch and the rear gate switch. Tail lights also flash now.
For the record, it's "charm.Li" (that's an 'el' after the period). The "li" domain is registered in Liechtenstein.
SpareParts
SpareParts
North Idaho
After researching code B2495 (Lift gate latch control circuit) and finding very little info about it seems the most likely problem is the main tail gate plug.
It does act like a wiring problem.
I had the main plug apart once and looked at the pins and they all looked good but maybe I missed something.
I'm going to start troubleshooting from that plug. Maybe the power pin is stretched and not making a good connection.
SpareParts
SpareParts
North Idaho
I can't seem to find a wiring diagram I can make sense of, but then again, I'm just about noob level when it comes to wiring.
Does anyone have the procedure for testing the lift gate module and wiring? I think that is what I need.
The diagram I can figure out I'm sure but it only shows where the wires come from and go to.
SpareParts
SpareParts
North Idaho
Either the motor was burned up or the module was bad on the original unit. I don't know what one as i could not find a test procedure for either.
I put an entire mechanism, module from a 2010 Escalade on it and a new clutch on it and it now works every time. The rear close switch never worked either but now it even does.
So finally got another annoying problem fixed.
On to the next!
Turns out after a few days it broke again!
SpareParts
SpareParts
North Idaho
This lift gate is sure a PITA and I think I burned out the new drive gear clutch part.
That drive gear has a gear you need to remove to replace it. The gear itself is a soft metal.
The gear rides on a small shoulder on the drive gear shaft. From normal ware a grove will form on the gear allowing it to sit slightly lower on the shaft. When tightened down it will bind against the housing creating a lot of drag. You really can't tell it has more drag than it should as it's pretty difficult to override the clutch anyway.
So new gear on the way.
kjetilaf
