Another lift question Yukon XL 2500
custom99
Pittsburgh, Pa
I am planning on a 6 inch suspension lift with 35's. Any issues that you can tell me about with this set up. This one will be on a 2001 Yukon XL 2500. I am using the Trail master lift (T54C4103SSV) and 315/75-16 on the stock rims. It will only be used for local and highway driving. No off road at all.
C
custom99
Pittsburgh, Pa
Update. Everything went good with the lift except the stock rims did not work. I used the trailmaster 6 inch lift. They dont tell you any where that the factory 16 inch wheels wont fit with the new spindles. The inner edge or the wheel hits the caliper. I just ground a small notch in the caliper until I picked up the new set of wheels and tires. I went with 16.5 rims so if anyone is thinking about doing this plan on new wheels with a different offset, use spacers, or a different diameter rim.IMG_5973_zps4e2671dc.jpg
BPB
16.5 will make it hard to find tires but it looks good!!!
McRib
