Another newbie question. What years wheels will fit my 2007 Tahoe
truckguy
I currently have chrome 20" wheels on my 2007 Tahoe. They rub a smidge when turning, but the biggest issue is that the chrome is flaking and I have to add air to 1 or more tires every couple days.
I'm due a new set of tires soon and would like to get some new wheels as well. I'm thinking 17's or 18's to cure both problems I'm currently having.
I found some 6bolt chevy wheels on FB Marketplace, but not sure what years will or won't fit my Tahoe. I'd hate to buy a used set and find out they don't work.
Thanks
I believe that there is a bolt pattern number for your truck, and someone here should be able to get you that number. Then, any wheels with that bolt pattern number could be used for your truck.
T
truckguy
Looks like I found my answer - 6x5.5 bolt pattern, same as used in every Tahoe/Silverado 1500 from 2007 to present if the site is correct.
B-train
Same pattern from 1988 and up on 1/2 ton trucks (4wd 88-98). Literally anything 17 inch or bigger from those years will fit. Most likely have to go 2007 and newer like you stated.
Anything from silverado, sierra, tahoe, yukon, escalade models will bolt right on. Even nissan armada wheels work
CaptainAmerica1
Arlington TX
And Dodge Ram 6x139.7 Rims too…
davidmakey230
