Another Upstate Newbe
S
smithl3
Started the install today. It's been a while since I have worked in a few year old suspension in NY, the salt doesn't help anything. Pretty slow but I managed to get the front end done and the sway bar installed in a little over 4 hours. I took my time and made sure to use antisieze and torque everything. Tomorrow is the lowering of rear.
S
smithl3
Just dropped it off for an alignment and a tire pressure sensor calibration.
Fosscore
That long Suburban with the 375s looks sweeeet!
S
smithl3
So I just picked up the suburban from the alignment, the only thing that I noticed is that there is rubbing on the rear wheels against the fender liner. I ended up driving it probably 20 miles and noticed occasional rubbing hear and there. When I got home there was indication on each side of the rear fenders that I will need to cut off to allow for clearance with the wheels and lowering kit. I only really notice it when I side load the tires with a left or right turn. The axle is in the dead center of the truck, I used a straight edge and adjusted the pan hard bar to within a 1/16 of an inch, so I cant blame it on axle position.
Has anyone else experienced this? I am hoping to simply relieve it a little bit and solve the problems, I hope it is that simple. I also occasionally get slight rubbing on the front fender well on particular wheel angles and bumps. It looks extremely close to rubbing at times but mostly clears.
S
smithl3
With a heat gun and a 2x4 I was able to push the protruding parts of the fender well out of the way. I have a few hundred miles on it at this point and haven't heard a single thing rub in the back anymore, looks like the problem is solved.
pipehand903
