Antifreeze disappearing
chozen1
06 esky awd. When driving fir ling periods, i can smell antifreeze burning. I have replaced thermostat and lower hose. There are no visible leaks. I checked the passenger floor for wetness and nothing. Truck never runs hot. I'm at a loss. Where can the fluid be going?
Sent from my SM-N900T using Tapatalk
casper1102
South Dakota
I was losing antifreeze at the plastic connector at the firewall, I was losing quite a bit and could smell it burning. Ended up being a cheap fix
Sent from my SM-N920V using Tapatalk
C
chozen1
I'll check that out now. Im about to change the oil sending unit
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Look at the water pump weep hole. When they start leaking out of the weep hole it can be very minute and it will actually evaporate from engine heat before it hits the ground (You will smell it but not see it). Though having said that, evaporating antifreeze will leave behind a crusty gree, residue. Look for that residue around the water pump weep hole.
C
chozen1
casper1102 that is exactly where the leak is. While changing the unit, i felt around the connections and one was wet. I will change the connector in the am and fill the system back up.
Thanks a bunch.
casper1102
South Dakota
I'm not sure it was cold out when I found my leak and I had a warranty so I didn't fix it myself
pipehand903
