kaleburditt
- Joined
- Apr 25, 2019
- Posts
- 15
- Reaction score
- 9
I have 08 yukon denali with the 6.2 and kept vvt. I stroked it and supercharged it. I got exactly what i wanted and that was to tow up hill and across country in converter lockup. Problem is overheating. Obviously 1600 rpms aren't enough to keep it cool enough. For that matter neither is 2200. I replaced the radiator with a monster. Added external transmission cooler and in the process of oil cooler as well. But it still overheats. I think I just need extra air flow or water flow and I would be good. My water pump outlet comes out the top of the pump and with vvt, its apparently a different mounting as well. Has anyone had success with aftermarket performance pumps that specifically work better at the lower rpm? I never go over 4000 rpms so even an electric pump or smaller pulley would work? Maybe use an LS3 pump and get a new water return hose?
Edelbrock claims they don't make one. March doesn't make pulleys for it. FlowKooler are currently out of stock and its only for an ls2, and meziere doesn't seem to have the appropriate application either.
With a L92 I am having a difficult time sorting through the applicable cross references on which water pumps I can use. OR even if i need one. There doesn't seem to be definitive answers to flow rates of oem and after market pumps especially at closer to the idle and cruise ranges. If I could get away with just upgraded electric fans I would take that option as well although I see unconfirmed that stock flows 5500 cfm already.
